cb34
- Oct 31, 2011
Brand ,size and lenght....
I agree, don’t look at what pound it’s rated at look at diameter. 175# jinkai 150#hi catch 130#diamond are all 1.28mm. Momoi likes to advertise that diamond breaks at 200% of stated line test when they are really just taking 200lb line and labeling it 130#Really w/ mono - outside of liking how it handles, trusting it, the key thing is look at the diameter.
Brands and styles vary on line rating versus diameter. Typically thicker stuff for the # rating will way over-test and thinner stuff breaks closer to it's rating.
With Jinkai the 150# is closer to a 150# break strength, and I like how that handles as well as the heavier versions. But I dislike the lighter versions of Jinkai - I do not use it in anything < 150, has this tendency to turn into what I can only describe as silly string. So I use a different brand for lighter stuff.
200 Diamond. 250yds to start and cut it back to about 200 before replacing.
For bft or for canyons?130 Diamond
BFT. 130 diamond breaks at 200lbs consistently. Never broken a topshot even at full drag.For bft or for canyons?
Ya I have only see one topshot break and it was 200lb dimomd, must have been a nic or something in the line.BFT. 130 diamond breaks at 200lbs consistently. Never broken a topshot even at full drag.
