Bill_N
Got the oil sample results a TD 5061A -
Dealer Comment: Note the comment that sodium levels are above normal indicating that there is a possibility of salt water contamination in the fluid. This could only come from the oil fill cap if loose for some reason or the oil cooler is leaking. I would recommend having the oil cooler removed and pressure tested to determine if it needs to be replaced.
So if the oil cooler was found to be leaking and was replaced. Would the gear be OK?
Contaminants (ppm)
Silicon (Si) 10
Sodium (Na) 202
Potassium (K) <5
Water (%) <0.05Dealer Comment: Note the comment that sodium levels are above normal indicating that there is a possibility of salt water contamination in the fluid. This could only come from the oil fill cap if loose for some reason or the oil cooler is leaking. I would recommend having the oil cooler removed and pressure tested to determine if it needs to be replaced.
