Capt. Lou
Anyone have tuna tubes?? i just purchased the double kodiak set up. Going to use them to keep bluefish alive for tuna/ shark fishing. I have received conflicting recommendations on pump size for the double tube. one place said you need at least 360 gph per tube. and the other guy i talked to said you need at least a 1600 gph pump to run them both. ideally i would like to connect to my wash down pump. its a rule general purpose 3800 gph i believe. can i install a valve to control flow to tubes or will restricting the flow of the rule 3800 cause too much pressure? as always any ideas and comments are appreciated.
