A 25 yr old 26' Duffy has a 1 1/2" bronze shaft and a vented shaft cutlass bearing. It needs replacing. The surveyor noted the bearing to prop distance of 3 1/2" was longer than recommended (over 2 diameters I think he said). If I don't wish to cut down the shaft and re-key, is it sensible to press in a longer bronze sleeved cutlass and have it stick out say 3/4"? Would that effectively move the center of support aft 3/4"? If doubtful, any harm in doing?
No sign spurs and no wear marks to note the shaft had ever been more forward than now. But it had been re-powered with an identical TAMD31, though it was now the P version not the A, and as the forward clearance of the SW pump and deck cutout is only 1/2", maybe they had to move the whole engine aft to fit the opening??
Thanks for comments.
