Capt. Rick
Question for someone here who may have run into this before. My boat is relatively new, 600 hours - she is a RP Willis Beal 31 with a Volvo 435 D6. I am getting a slight vibration between 1600 to 1800 (7-8 Knots). Above and below that she is smooth. The shaft and prop are perfect, they were pulled and checked twice. Seems to be a motor mount issue. My builder installed the Volvo "recreational" style of mounts. They seem to be pretty "cushy". They are bolted to heavy steel angles, everything is tight. I do not like having this vibration, and would like to address the problem. Has any of you ever run into this same issue with the Volvo motor mounts?
