Downeaster
There are a couple of current threads that touch on this subject so I'll toss in a couple of quick and dirty stats or remedies that are often overlooked or just unknown.
Prop wash against the hull isn't just a blade-induced pressure wave causing a knock on the hull but it is also a once-per-(blade) revolution pressure on the shaft and bearings. There is a standard wheel size to a given aperture and it calls for 17% of the wheel diameter for blade tip clearance to the hull (Gerr). For instance, a 20" diameter wheel would have to have a minimum, blade tip-to-hull distance of 3.4". How does yours measure up?
Another issue is soft engine mounts. If you elect to go with these, you want to soft mount the transmission-to-shaft coupling too (Downeaster). If you you have soft engine mounts and a solid transmission-to-shaft coupling, what is going to absorb the engine's movement? I've heard good things about ACE engine mounts (Pascoe et al) and they are scheduled for my next build.
I haven't seen the video mentioned in other threads but here are a few quick tips that are often overlooked:
- Of the pair, the thin nut should butt up against the propeller hub.
- Dry fit your propeller without the keystock in the keyway and mark the shaft with a pencil - then reinstall the keystock and make sure that the propeller hub reaches the pencil mark.
- Your final shaft alignment check has to be done with the boat in the water (preferably for a few days after launch), not on the hard.
- According to the National Fisherman (Feb 2011), you're aiming for shaft-transmission alignment of 0.004" or less.
