- Sep 1, 2011
- Age
- 57
- Location
- Boston Ma.
- Website
- www.bostonharborcharters.com
- Boat Make
- 33 Flowers.
Anyone got an idea for a wall/floor/bulkhead ect.... mount for an inch & half 1 1/2 deck hose fitting ? Double ended barb with some sort of center mounting plate ???
The only thing I've ever seen is possibly something from a fire dept supply type place .
I made my own on my Parker by taking a double ended PVC 1 1/2 barbed fitting, took the biggest PVC nut I could find, took a die grinder to the inner thread part of the nut till I had it fitting snug to the center of the barb fitting and epoxied it. Drilled 4 1/8 holes through outer part of nut for screws to mount, hose on each side w clamps after mounted to a wall.
Want to feed my rule 17a pump - 1 1-2 hose under deck to an air box under gunwales. Mount a fitting through the air box and then attach deck hose.
Thanks.
Thanks.
