washdown pump
Discussion in 'Downeast Boat General Discussion' started by moetuna, Sep 9, 2019.
  1. moetuna
    moetuna Senior Member
    Feb 12, 2014
    308
    49
    So I have a rule 3700 centrifugal pump that's working at 20% capacity . I think it might be clogged with grass/seaweed . I can only see the back end of it and its going to be a chore working on this thing in the space that I have. I think they built the boat around the pump ! Anyway , before I destroy it trying to get it out I wanted to know if anyone knows how they come apart for cleaning . Maybe I can do that without total removal . Thank you RUL17A-2T.jpg
  2. BillD
    BillD Captain
    5,997
    1,672
    Business owner
    seems you.d squeeze the two red tabs together and slide the pump off the bracket..No ?
    Impeller is there
    moetuna likes this.
  3. moetuna
    Feb 12, 2014
    308
    49
    Im not sure what you mean by the 2 red tabs . I see a red tab at the top . Is there one on the bottom ? What are those rectangular ears s to speak about ? I wish I had one of these to hold in my hands . Like I said very difficult to see and get at on the boat .
  4. Genius
    2,572
    1,276
    looks like there are red tangs that go into the white sockets. Probably a small screw driver or something to disengage.
    moetuna likes this.
  5. c1steve
    c1steve Senior Member
    Jan 30, 2017
    365
    93
    Yes, push in the red tangs and it will slide apart. This is a bilge pump with a different base. Usually you do not need a tool to separate the base from the pump.
    Rule sells the base separate, might be able to find it on their websited.
    moetuna likes this.
  6. EarlDuke02
    EarlDuke02 Member
    Nov 1, 2015
    14
    Deer Isle, ME
    27 H&H
    There are six screws in the end cap. Three are short which hold the white end cap on, three are long which hold the red base on.
    moetuna and Tunatown like this.
  7. Tunatown
    Tunatown Captain
    Jan 25, 2016
    519
    263
    Lineman
    Plymouth Ma
    36 H&H CAT 3126B 420hp
    No push tabs screws as earl said you can rotate and screw it in different angles
    moetuna likes this.
