bestfish
I know this has been discussed before, but I can't find it. Which Gel Coat for a final coat? Going to be a rough finish, not shiney. Is no wax gel coat ok? Someone told me it won't fully cure and now I'm scared.
THIS IS INCORRECT!!!......no wax if you want to do multiple coats.....then last coat must have wax or sprayed with PVA to cure....another trick to ad shine is to ad patch aid to the last coat...it will shine niceLast coat unwaxed or it will be sticky for a very long time.
WITH wax final coat, and depending which part of the boat you are doing and how nice of a finish you want mix gelcoat with Duretec high gloss clear.
Duretech seals the final coat of waxed gelcoat great! Seems to cure a lot "harder" than just straight waxed gc.
Bestfish call joe @ Merton’s fiberglass. He has everything you need and great advice. 413 736 0348
Do you still wet sand and buff if you add the duretec?WITH wax final coat, and depending which part of the boat you are doing and how nice of a finish you want mix gelcoat with Duretec high gloss clear.
