by the way, That live well looks badassReplacing and adding new holders in a 32 Holland and was wondering what the latest thought is on rod holder choices (degrees & depth) in the corners, transom & gunnels. Thank you for any advice.
thanks guys. Will do. Would you go with 15 deg on the helm holder midship or stick with a 90?by the way, That live well looks badass
I would go 90.thanks guys. Will do. Would you go with 15 deg on the helm holder midship or stick with a 90?
Thanks guys for your input.I would go 90.
That’s brilliant. Thanks Yoda!I like fighting with 0 degrees for the first part then when the fish is straight down switch to 15 degrees so the line is nearly 90 degrees off the rod. Big help with heavy rods. This is how i accomplish the switch over. At 90 degrees the butt as pinned straight. (you can see the holes just in front of the fwd. screws). I just pull the pin and drop the rod. Easy. I also have the option to pump the fish at any time in the fight. I can go 15 degrees either way from 90.
Leaky is right about the rod swinging up while in a angled holder You have to be careful about that. Better to move the boat.
.1st one is all the way in and the other 2 are out. (Works for me).View attachment 125557 View attachment 125558 View attachment 125559
Lou, I call them 90 degrees because i look at the surface of the horizon as 0 degrees. You know like when i fall down and stop at 0.I think you guys saying 90 degree really mean 0 degree. I have about 16 rod holders on my boat all but two are 0 degree and the remaining two are 15 degree. Im my opinion bent butts are well suited for 0 degree holders and bend the rod better than a 15 degree while the fight is on.
Don you get a pass. You can call them whatever you want. I have been going up to jackman quite a bit. Love to catch up some time when im cutting thru.Lou, I call them 90 degrees because i look at the surface of the horizon as 0 degrees. You know like when i fall down and stop at 0.JK.
Love what you are doing. I would add a toe space on the bottom. I know its a bit more work but it will keep you from bumping your feet. Looks like a nice job being done.Replacing and adding new holders in a 32 Holland and was wondering what the latest thought is on rod holder choices (degrees & depth) in the corners, transom & gunnels. Thank you for any advice.
Dont you like swivel rod holders and bent butts ? You cant use 15 degree with swivel holder and a bent butt. I have a video of you in action on a zero degree set up. Watch how quickly that fish changed direction when it got near the transom but to deep to toss and how many times it did that and then tell me how you would have made out with a 15 degree holder that didnt swivel. When the fish is that close its hard to get the stern to react that quickly. A 0 degree swivel reacts for you where as the 15 degree cant because its not going to swivel. Leave the 15 degree to the bass and blues.I like fighting fish out of 15 rather then 0, 3 15on stern and 3 on port and and 3 on starboard.
