What is this Material?
Discussion in 'Downeast Projects and Boat Building' started by Fish220sr, Sep 13, 2019 at 10:00 PM.
  1. Fish220sr
    Fish220sr Senior Member
    Sep 3, 2011
    403
    120
    Contractor
    Long Island
    29' Webbers Cove
    Hi. This Dark Grey material was used on the inside deck.The same material in flat form without the bumps was used on the main and upper decks.The areas were painted with Interlux Perfection 2 Part Epoxy Paint.What is this Dark Grey material? Besides a Rorschach test IMG_8806 (1).jpg View attachment 74260
  2. Blitzen
    Blitzen Captain
    3,778
    2,255
    Ex Merchant Mariner
    Clay,
    Blast and prime and paint or re-gel coat after blasting.
    Fish220sr likes this.
  3. Fish220sr
    Sep 3, 2011
    403
    120
    Contractor
    Long Island
    29' Webbers Cove
    John -Thank you for the advice.The Hull and House exterior are Gel coat.All other parts are painted.Blasting would be a challenge! Results are generally always greatbut OH what a Pita!
    Do you off hand know if this Dark Grey material has a "name" ?Thanks again.
    By the way your Flower's 46 looks Killer!!
  4. Blitzen
    Blitzen Captain
    3,778
    2,255
    Ex Merchant Mariner
    Clay, I have now idea what that stuff might be.
  5. Fish220sr
    Sep 3, 2011
    403
    120
    Contractor
    Long Island
    29' Webbers Cove
    Yeah,my tech has no idea either!
  6. Keelboater
    Keelboater Captain
    5,008
    2,919
    Looks like it was troweled on as a coating. Some kind of thickened epoxy perhaps?
  7. El Mar
    El Mar Captain
    6,806
    2,511
    Is it sheet stock?
    Looks like coosa board.
    I used a piece here to create a block for a seacock.
    These are covered with epoxy and cloth but you can see the raw edges.
  8. Toolate
    Toolate Captain
    5,721
    1,686
    Building contractor
    Old Mud, kcassells and Fish220sr like this.
  9. Fish220sr
    Sep 3, 2011
    403
    120
    Contractor
    Long Island
    29' Webbers Cove
    El Mar- We have a Contender for what the material may possibly be made of.Thanks.
  10. Fish220sr
    Sep 3, 2011
    403
    120
    Contractor
    Long Island
    29' Webbers Cove
    And the Master builder from Conn. says "Looks like a pair of boobs to me ".There we go,we did not have to wait for someone more experienced to comment. A possible Rorschach fellow veteran.
    Toolate and kcassells like this.
  11. Quik Fix 16
    Quik Fix 16 Senior Member
    Jan 29, 2019
    141
    Fiiberglass guy
    Emerald Isle, N.C.
    Shamrock
    Looks like a woven roven that was gelcoated grey, then painted.
  12. Fish220sr
    Sep 3, 2011
    403
    120
    Contractor
    Long Island
    29' Webbers Cove
    Timeline for material useage is the hull is solid fiberglass layed up in 1998. The boat was commissioned in 2001. A Dentist in his late 80's from Brick,NJ had the boat built.
    "Looks like a woven roven that was gelcoated grey, then painted." Quik Fix . Searched around and found lots of info on woven roven in comparison to Biaxel.
    Keelboater and Genius are very knowlegable on all things boat related.Does the "like" comments imply agreement with Quik Fix's answer? The "Grey Material" if it is woven roving is not compatible with the two part epoxy leading back to Blitzen's initial suggestion. Thank you all for information and suggestions.
  13. Genius
    2,572
    1,276
    Just sand it with 40 grit. Angle sander or orbital if that's all you have. Get a good surface for whatever you are applying. Acetone wipe after sand. What's your plans for coating afterwards?
    Edit: I don't think perfection is an epoxy paint is it? I thought it was a two part polyurethane. Not that it matters but FYI. Before using this....if that is what you are doing. Use the primer for it would be my suggestion.
  14. Fish220sr
    Sep 3, 2011
    403
    120
    Contractor
    Long Island
    29' Webbers Cove
