What's the biggest sub 30' DE without motor box?
133
I keep going back and forth with bigger vs smaller but the simplicity of a big, sub 30' is becoming more appealing. Curious what best under 30' is in your opinions?
Thank you!
Tuna Hotline
28 BHM can be had without a box, but depending on the engine, you might lose some significant headroom.
Powderpro
The Ocean
www.oneilboats.com
O'Neil
Are you talking new build or used ? I’m pretty sure a lot of the AJ28’s had no engine box, I’ve seen some 28’ Nausets with no engine box. Not a lot of under 30’s with no engine box
133
thank you. im looking for used. I dont know much about the AJ.
back 8-9 years ago I took a ride to the Cape to look at a 29 H&H with no engine box with sedan sides.
Low profile Yanmar 6LP 440 under the deck and he had the boat layed up with an extra 3 inches of shear.
Corresondingly the house was heightened by a similar amount with the "cut" just below the windshield.
Can't remember the charter name
Extra height looked fine
No box
I've never seen a 29 H&H without a box.
Like PowderPro stated...not many 30s and under without an engine box unless you are running an opposing cylinder horizontal power plant like a Porsche Boxster or Subaru :eek:
jdickau484
Ninigret Pond, RI
Jordan
22' Calvin Beal
chortle
Annapolis, MD
Thank you!
Dyer 29 is pretty nice, some do come with an engine box. Here is a video of one that does not have a box.
Frank Grimes
N41°41'46.91" W070°15'35.13"
I feel like I should know the answer to this question, alas I do not, so I will ask. Is the 29' Webber's (Coombs) Cove just a 26' WC with a 3' extension, or is it an entirely different hull with a larger beam?
Powderpro
The Ocean
www.oneilboats.com
O'Neil
I asked John and he says the 26 and 29 are the same hull, the top will fit either hull.
