Getting close to the time where I need to have the tank built for my 32 Holland, is basically an atop the deck tank in the ballpark of 7 X 2 X 2 ft with some deviations from a straight rectangle shape, in the 180 gallon range.
I think the easiest way to go at this is going to be to build a pattern out of plywood, sketch out fittings and all that, then put it in the truck & go drop it off to someone.
Where do you guys figure I should go, and any idea of a ballpark cost I should expect?
Since I'd be driving there would be nice to end up say someplace north of Boston and south of Portland, not a hard requirement just for sure not 2+ hours away.
Thanks in advance!
Thanks in advance!
