mattinri
The aluminum frames on my Diamond Seaglaze windows are corroding. One slider frame separated. The front windows have leaks in the corners where the salt corroded through. I've got a Duffy 35' with three aluminum opening windows in the front. I'm assuming they can't be sent back for frame repair and need to be replaced? Are the sizes custom or stocked? should I stick with Diamond SeaGlaze? Lastly, is this a DIY project for a guy with no skills or should I source it out?
