Wtb Hynautic steering pump
kapnd
I have been looking for same for quite some time. If you find a source, let me know, I'll do the same for you!
1oldbuzzard
I have a freshly rebuilt H25 .I may be willing to part with it.
PM Me Thanks
kapnd
PM Me Thanks
Your PM box is inop.
How can I id the helm pump? It has no numbers or id plate, just big squae chunks of alumium bolted together.
I know it has to be Hynautic, the rest of the system components are plainly marked, except for the helm pump.
What's the difference between H-21 and H-25?
Can I substitute any hydraulic helm for the hynautic?
maineguides
It will have a h21 or h25 stamped into the aluminum. The h21 is a one inch straight shaft and the h25 is a 3/4" tapered shaft. Other than that they are the same
kapnd
Mainguides, Thanks for the info, guess all I need to do is pull the wheel off to determine #. I want to add a station at the deck, not entirely sure yet if I will use a helm with wheel or a dodger hooked up to the autopilot.
1Oldbuzzard, how much are you asking for your spare unit?
